Q100H spoke flange dimensions.
Does anyone have the spoke flange dimensions and hole count for the Q100H hub motor?
I have had a hard time finding an decisive info. I'm asking because I have one ordered from BMS and would like to be prepared for when it arrives.
Cheers!
100 milimeters, that's why it's called a Q100.
The come w/ 32 or 36 holes.
I used to think the same thing about the Q100/128 but when I laced a couple Q100C motors the drawings indicated 109mm flange diameter which I used and everything fit well.
But somewhat oddly, the Q128H were indeed 128mm.
Perhaps the Q100H is different flange diameter than the CST version but they don't have any drawings for those CST?
I have heard that all the Cute 100 hub motors use the same case.
Some time ago I did a drawing of the Cute 100 Front hub and its spoke ring was 108 mm as well.
https://endless-sphere.com/forums/viewtopic.php?f=3&t=58783
Reference:
http://www.keywild.com/cad_library/KeyWild_Cad_Library_index.htm
I stand corrected, and yes, all Q100 hubs are the same.
Sweet. That's just what I needed.
Now for deciding what bike to put it on......aka the tough part :D
Second question,
Is the hub definitely 32 hole?
boogieBeats said:
Second question,
Negative. Most motor hubs are 36 spokes. There are a few that are 32. Unless otherwise stated I would always assume 36 spokes.
LewTwo said:
boogieBeats said:
Second question,
I was confused because BMS had listed the Q100 CST as 32.
https://bmsbattery.com/ebike-kit/651-q100c-cst-36v350w-32-hole-rear-driving-hub-motor-ebike-kit.html
I guess I'll wait for the motor to come in. When it does I'll measure it up and post something definitive.
Yep ... note that is the hub motor listing on their site that mentions the spoke count.
I measured the hub. The dimenions here should provide enough info to lace a wheel up.
Accurate to 1 mm.
Q100H Dimensions.
