"Best" and "ideal" depend first on what you need the battery and system to do for you. After that, how long a lifespan you need for the battery before you replace it comes into play, and thus consideration of how full to charge it or how empty to discharge it.
Is the percentage you note the actual percentage of Wh or Ah capacity? Or some other percentage? If you are not sure, then what equipment is being used to measure this?
First, does this specific battery, by itself (not a different one, or this one in combination with any other) take 35% of it's Wh capacity to make the trip?
(if you are using any other batteries to determine or measure any of this, then those measurements don't directly apply to this one, and you will need to provide specific Wh numbers for each battery's capacity, and preferably your Wh/km usage, to compare to this battery's Wh (which if that hasn't been measured, would have to be guesstimated based on it's stated average voltage and stated usable Ah capacity...which could be very different than it's actual Wh capacity)
Is that under even worst-case conditions?
If so, then you don't necessarily need the extra 30%, and can charge to a lower voltage (set HVC lower), and discharge to a higher one (set LVC higher).
However, there are some times you might need that extra, or even more (requiring the at-destination recharge):
If the conditions you measured under are ideal, rather than worst-case, and don't include any adverse conditions like headwinds, detours, poor road conditions, etc., you might need some or all of that capacity to get where you're going (and back).
Also, as the pack ages, it will lose capacity, and you may need those extra Wh (they may no longer be extra).
