sl33py
There are quite a few hot wire kits and how-to's out there...
It's not rocket science - some simple nichrome wire and set the voltage/amps for temperature you want.
I was going to fab up a nice sturdy spreader to keep the wire tensioned, but figured a quick cut or two on the foam to get it to a more manageable size would make it easier.
Let's make it simple - you get a certain gauge of nichrome wire which has a known (or measured) resistance. You then use a measured length (or measure resistance of your length), and use a power supply with that voltage/amps to get your target heat to cut through the foam.
For a good calculator:
Do the math or use the calculator here.
Here's the cheatsheet on the wire gauge, length, and volts/amps needed for your temp range. (hotter cuts faster - not rocket science).
Inexpensive "vape" wire - $9.50 for 100 feet!
Now to my "fancy" setup...
I just took some of the 28g nichrome wire and strung it on this bike rack (was using as a place to set my board). Insulated and worked pretty well if i do say myself. Leaves my hands free to keep the cuts reasonably straight.
So $10 and the cost of the lab power supply i already had. You can do the calculations and easily find a 5v 2a (like just about every USB phone charger around now). You can do the calcs and add some resistors to fine tune your temp. Lots of options!
I plan on getting a table top setup for this next. Just to make it easier to keep tension and 90* perpendicular/square cuts. I'm planning to use the foam for both GF/CF layup and vacuum molds for Kydex/ABS. So i want to get it close and then finish sand it to the shape i want. The better it looks the better the forms will work out.
OK, you can now proceed to make fun of my messy bench!
