SilverSurfer
Yes, I been into a strong headwind and dang its a push! I am going to consider some options for aerodynamic solution, but it has to look very professional. On the streets lots of folks think I bought it this way because its not very "DIY" looking. I like the idea of cylinders some, easy to come by, and in polished aluminum, it would bling like chrome. Or maybe an added fairing to the boxes I got. thanks for the ideas. in this stage, every idea has potential. SS
John in CR said:SS,
Not only are you forcing those 2 flat surfaces through the wind, but at the back you have a vacuum that is pulling reward. If you ever ride into headwinds the effect of those flat surfaces would be huge, and with no wind I guarantee it's costing you over 1mph in top speed. The bike is so cool, I'm thinking of copying it.
Something nice and easy could work, because since that chainguard is dead straight, you can get away with a flat top and bottom. Try it with posterboard to check out the look. 3 ideas are:
1. Use a piece of larger diameter pvc pipe, or sheet plastic or metal to make a half cylinder to simply round the front and back. If you make them a bit longer than the ammo boxes are high and a sheet of something thin to cover the sides, then you could easily straighten out the slightly off angle of the boxes.
2. Better aero than just both rounded could be accomplished with a long piece of sheet aluminum or plastic. Just rivet or glue the 2 ends together face to face to form the rear point. Put it over the ammo boxes and attach with the rounded end in front. The top and bottom would make it form the perfect teardrop shape, as well as give you storage space with a flip up top. Using sheet aluminum you could add little weight and might not even need to paint it.
3. Similar to number 2, but just make the side closest to the bike flat by using something like a piece of plywood. Then use sheet AL, plastic, or even very thin plywood to bend around the ammo box.
