MotoMel
I purchase lithium batteries for use in electric bicycles. Batteries specially created for this use are usually encased and have a pair of discharge wires and a 3-prong connector for recharge. These batteries are rated 36V or 24V and 10-14 AH.
The respectively volted charger that plugs into them is of the simple plug-it-in-and-go variety, with no programming or connections to balancing wires required. So can it be assumed that these batteries have an onboard battery management system (BMS)?
It would be great to consider using Turnigy's or other RC-type lithium batteries, whose physical configuration could be arranged to fit in various containers. But expecting the typical eBike customer to fiddle with programmable balancing chargers with all the extra wires and equipment is hardly realistic. Is there a BMS that can be packaged with the battery so that a simple charger can be used with them?
