Thanks for all the great advice!
LewTwo said:
http://www.ebay.com/itm/Super-light-Lithium-wide-battery-alum-rear-rack-fits-26-29er-bike-silver-/271935159336?hash=item3f50993c28
http://www.ebay.com/itm/Electric-bike-battery-rear-rack-fits-26-29-bike-frame-silver-Alum-very-light-/281620779413?hash=item4191e81195
I have the first and to say that I am not impressed is an understatement. Not been able to find well designed one yet. I have contemplated using a standard rack and attach a rack frame to the top of the battery.
I checked my battery's aluminum case dimensions 400 x 150 x 80mm (15.75 x 5.9 x 3.15 inches) and it will not fit inside your first linked bike rack assuming I have the correct inside dimensions - 375 x 155 x 70mm (14.76 x 6.1 x 2.76 inches). Looks like I will have a height problem (3.15" versus 2.76"). Here is a link to the battery I ordered:
http://www.aliexpress.com/store/product/48V-20AH-Electric-Bicycle-Lithium-Battery-with-BMS-Charger-Rear-rack-Aluminum-battery-48V-1000W-Samsung/1714144_32309134019.html
Here is a link to where I found the rack's inside dimensions (look for yellow highlighted dimensions) :
http://www.aliexpress.com/item/high-quality-20-inch-Double-layer-Cycling-Bicycle-Bike-black-Rear-Rack-Luggage-Carrier-Stander-Back/2031934548.html
Do you know what the inside dimensions are on your second linked bike rack?
mark5 said:
Careful, I think apar_ebikes, the eBay seller above, is Busettii who have a bad reputation for poor service and misrepresenting their ebike and motor kits. There's also a similar rack from Amazon seller "E Bike Factory" who is Busettii.
Enough said, I will not purchase anything from a vendor who is known for poor service and misrepresenting their products. The search continues.....
Alan B said:
Putting all the battery weight back there is convenient but not great for system balance, unless this is for front motor.
My build is for a 48V 1000W direct drive front wheel motor. Here is a link to the conversion kit I have on order:
http://www.ebay.com/itm/48V1000W-26-Front-Wheel-Electric-Bicycle-LCD-Display-Motor-E-Bike-Conversion-/371159330505?hash=item566ad1eec9
tmho said:
I sold the attached one for CAD15 a few months ago. Hope you could find one soon.
WOW, that rack is just what I need! When and where can I buy one?
I'm not having any luck finding a double layer rack that will work and is reasonably priced (<$50 Delivered).
Any recommendations for a good single layer rack that will work with my battery? Does anybody have experience with the following rack:
http://www.ebay.com/itm/Cycling-Bicycle-MTB-Bike-Rear-Rack-Luggage-Carrier-Shelf-Bracket-Seat-Post-Mount-/281753019463?hash=item4199c9e447
