it wuz him ossifer.Chalo said:Did someone gore your rat? Just asking.
he did it!
http://endless-sphere.com/forums/viewtopic.php?f=3&t=41798
Why do you think that any other 3 speed hub is going to be significantly more efficient than the SRAM?o00scorpion00o said:I'm wondering what the most efficient 3 speed hub would be and that's an easy replacement for the SRAM dual drive II ?
Miles said:Why do you think that any other 3 speed hub is going to be significantly more efficient than the SRAM?o00scorpion00o said:I'm wondering what the most efficient 3 speed hub would be and that's an easy replacement for the SRAM dual drive II ?
Do you notice less drag when using the SRAM in second (hub) gear?o00scorpion00o said:Miles said:Why do you think that any other 3 speed hub is going to be significantly more efficient than the SRAM?o00scorpion00o said:I'm wondering what the most efficient 3 speed hub would be and that's an easy replacement for the SRAM dual drive II ?
I don't know that's why I'm asking.
The innards of the SRAM Dual-Drive are the same as that of the SRAM 3 speed. The present SRAM 3 speed is basically the same as the Sachs 3 speed as Sachs were acquired by SRAM in the '90s. Efficiency is probably as good as you'll get...speedmd said:Look at the test report bootjuice listed on page 2 of this thread. No Idea where the SRAM fits in. Would imagine it is not that good if your feeling a drag, but have no experience with them.
waynebergman said:Toolman, I did not know you had to shift one gear at a time with the rohloff? Are you saying you can not just go from 5th to 14 th in one jump? If this is the case I can scratch this hub from my wish list for sure.
