Hillhater said:
..fair comments guys, but..
...There is no data to quantify any capacity loss due to the higher charge rate.
..and true , Redilast,...those capacity maps are only representative for the one discharge rate ...0.2 A
..and the one used (0.2A discharge) , is not relavent to these tests.
DA,..do yo have any higher rate discharge capacity maps ?
There is another thread where someone did some cycle life testing on some cells with like a 1C charge rate, and there was considerable capacity loss after even just 100 cycles. Like 50% capacity loss. From everything I've read and researched in the past, what is most damaging is right before the current starts to taper off (e.g. on the high voltage end of the CC phase before it switches to CV). 1C charging would probably be fine for cycle life if it wasn't using CC/CV, but instead decreased current above 4v or so. For example CC to 4v, then 75% reduction in charge rate to 4.2v then CV with gradual taper down of current till a low termination current in the 50-100mA range. Maybe someone recalls the thread, or heck it could even be somewhere in this one on another page...
As for higher discharge tests, you can see 7A tests here of the 29E http://lygte-info.dk/review/batteries2012/Common18650comparator.php
Select The Samsung 29E from the drop-down then select 7A. Around 20-25% capacity remaining at 3.1v under a 7A load for example.
