cruiserbikeman
- Joined
- Jan 2, 2012
- Messages
- 82
I have an electric tricycle that is powered by four 12 volt 12ah sealed lead acid batteries connected in series which equals 48 volts 12ah. I decided to switch to a 48 volt 15ah lifepo4 battery and use different components (controller,throttle,etc.) but use the hub motor (450 watts) that came with the tricycle. Connected everything and the motor spins like a 48 volt connected battery is supposed to. The problem with a lifepo4 battery is that even though it weighs only 16 1/2 pounds it just doesn't have the pulling power the sealed lead acid batteries have. The speed was much slower with the lifepo4 as well even though the sealed lead acid battery weighs over 40 pounds. Another thing is the motor gets hot with the lifepo4. Now I use my tricycle to carry heavy groceries (gallon milk, gallon liquid detergent, gallon bleach, 4 pound bag sugar, 5 pound ground beef, candy, 4 21 ounce bags cereal, snacks, napkins, cleanser) with the sealed lead acid batteries and the motor stays cool and is faster than if I was riding the tricycle with no groceries using the lifepo4 battery. I bet if I tried that with the lifepo4 the motor would overheat and go dead. Sealed lead acid batteries tend to get a bad rap for limited distance, but there is no contest when it comes to transporting heavy loads. So from my experience, sealed lead acid is the choice for carrying cargo while lifepo4 is good for two-wheeled bike riding.
