Astropower
Hello There,
I want to change motor to my E-Scooter.
My question: How can be, Small Brushless Motor, can be more powerfull compare to bigger Brushless motor ?
The winding is smaller
The magnets are smaller
Does the manufacturer give false information?
** Small motor cost 4 times more.
Here is the small Brushless Motor:
Specifications:
Stator Diameter: 68 mm
Stator Length: 45 mm
Motor Diameter: 80 mm
Motor Body Length:92 mm
Shaft Diameter: 8 mm
Weight: 1.6 kg
Motor Configuration: 12N14P
KV: 70 rpm/V
Voltage: 30-70 V
No-Load Current: 2A / 20V
Max Continuous Current: 85A / 60V
Max Continuous Power: 5000 W
Link
Here is the Bigger Brushless Motor:
MY1020 460V DC 2000W Electric Brushless Motor 4500RPM
Model: MOTOR MY1020
Output :2000W
Rated Speed:4500r/min (max:5400RPM)
Diameter:107mm(AS SIZE PICTURE)
Link
I would like to know what do you think about this.
Thanks.
Astro
Specifications:
Weight: 1.6 kg
KV: 70 rpm/V
Voltage: 30-70 V
Link
Model: MOTOR MY1020
Output :2000W
Link
Thanks.
Astro
