ccihon
I am selling my gently used 9C clone hub motor - it is laced to a 26" wheel, and I am including a fairly new KT Sine Wave 45W 18 mosfet controller - also some of the various items removed from my trike, as I recently swapped from this hub set up to a mid-drive. Photos of this gear on the trike can be seen here:
https://endless-sphere.com/forums/viewtopic.php?f=6&t=112009
Even with the heavy trike and rider, the thing was very fast and reliable. No battery is included, but I am including:
Generic 9C hub motor, marked 1000w, mounted to 26" rim, has hall and phase wires, 14mm/10mm flat axle, hardware, torque arm setup included - I think you need about a 140mm dropout so can be massaged into a standard 135mm frame, has 7 speed freewheel (14-28 I think)
KT Controller model KT48SVPRK-SJT02L - documentation for connectors readily available online - there are connectors for halls, display, pedal assist sensor, throttle, security lock (will include a switch for that), brake sensors, battery (headlamp connector is non-functional)
TWO displays: KT LCD3 (large screen two-piece), KT LCd5 - smaller, all in one with switches
Various bits, previously adapted to trike so may need rewiring as they were cut, spliced, extended, all are very standard, so use these or your own:
Throttle (thumb, PAS sensor, split quick-attach version), brake magnetic sensors, keyed security lock, other various stuff to make it a kit.
The good news is that this all works together really well, with tons of power. I've had the motor for a couple of years of light duty, and the controller is less than a year old.
How much? US $225 plus shipping to your US address. Paypal preferred.
