Hello everyone, I'm new to e-vehicle modding in general and I have a version 20 Razor Pocket Mod that my mother won from a promotion quite a while ago. It is currently sitting inactive in our basement because all of us are over the weight limit (150 pounds). From what research I have done, the weight limit seems to be dependent on the weight the motor can reasonably move without burning out. So, I would like to upgrade it to be useable by someone weighing around 250 pounds. Here's a list of what I plan to do:
Replace throttle (stock one is on-off) with http://www.amazon.com/ScootsUSA-109-3-4277-Electric-Scooter-Throttle/dp/B00H4GN83E/ref=sr_1_1?ie=UTF8&qid=1405962758&sr=8-1&keywords=hall+effect+throttle
Replace controller with either http://tncscooters.com/index.php?route=product/product&path=41_74&product_id=180 or http://www.ebay.com/itm/171321762971?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I've heard that the YK43B likes to burn out Unite motors, but some other opinions would be appreciated.
Replace the stock on/off switch with this http://www.ebay.com/itm/Auto-Battery-Cut-Off-Switch-Disconnect-Kill-Solid-Brass-With-2-Removable-Keys-/121050693426?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c2f2eff32&vxp=mtr Not sure if this is needed but I don't know what current/voltage the stock switch is rated for.
Replace the old 2x 12v 7AH batteries with three of these in series for 36v 15AH (right?) http://www.amazon.com/15AH-Sealed-Lead-Acid-Battery/dp/B0090W1OZE/ref=sr_1_300?s=automotive&ie=UTF8&qid=1405994207&sr=1-300 rigged up similar to this image
(credit to rxse7en on modifiedelectricscooters).
Replace the stock 24v 250w motor (MY1016-B) with http://www.ebay.com/itm/151232108134?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 running at 36v
I do have a few questions about my upgrades, though. Firstly, which controller should I go with? I would prefer not to burn out my motor, but will the lower-amperage controller be able to supply enough power for the motor? Next, will I need to change gearing to get it to run (fairly flat ground with a few small hills) with a 250+ pound rider? Stock has an 11 tooth motor sprocket and an 80 tooth wheel sprocket for a ratio of 7.27. Lastly, will I need to rewire the Pocket Mod with larger gauge wiring to support a more powerful motor/controller? Stock wiring is (I believe) 16 gauge in some places and 18 in others. I have 20+ feet of 12 gauge on hand, but I can easily get the same of 10 gauge.
Hopefully you guys can help me out with planning this build and hopefully I can get it up and running soon.
EDIT: I just noticed the label on the motor says ZY1020 rather than MY1020. Is this a knockoff motor and should I go with something different?
