maarkmohamed
- Joined
- Jan 10, 2019
- Messages
- 114
Hello guys, i currently have a sur ron motor and wanted to install on there a sprocket for a 420 chain, however i need help finding one given the measurements. The diameter of the shaft is 20mm. And then the shaft is also missing what i think is called the key, and that measured to about 16mm as seen in the image below. Any help greatly appreciated.
https://ibb.co/fCdXbhV
Thank you
Thank you
