SW900 and keyswitch
DaviddBro
Israel
Hey guys so i wanted to ask if its possible to connect a key switch to the SW900 Display what i mean by it is like when i turn on the Key witch to the on position the Display will Turn on without the need of pressing the Middle M Button to power on the display so i wanted to know if its possible to connect the wires or something to make the display power using the key switch
Here is the SW900 Wire Diagram
Red Line (D+): Power Positive
Black Line (GND): Power Negative
Blue Line (DS): Controller’s electric door lock
Brown Line (DD+): Lighting control’s Positive ( If the controller’s software and hardware support lighting control, do not need connect this line)
Green Line (RX): Receiving communication
Yellow Line (TX): Sending communication
White Line (GND): Lighting control’s Negative
the key switch has red and blue wires i did try connecting to same red and blue here but it doesn't turn on the display but it does power on the bike
