I have two of these batteries: http://www.electricbicycleworld.com/li-3/
They are 36V 11.6ah using Panasonic (Cell Model NCR18650PD). Typical cell capacity is 2880mAh and minimum cell capacity is 2730mAh.
I want to take the apart and use the cells to make a 48V 16.8ah battery. Would you advice against this? Would 48V provide a noticeable difference in the power of my motor? (It is a 500W Falco Direct Drive Hub Motor)
If so, are there suggestions for a good BMS and rear rack case to buy to put the cells in?
