Joseph C. said:liveforphysics said:Motivations we don't have the insight to see from our limited perspectives would include ability to directly retro-fit into existing battery pack volumes.
Nail on the head. A year from now Tesla will have to upgrade the Roadster batteries for the first customers who opted for a future pack cell replacement. Six years from now the first of the Model S's will undergo the same treatment.
Unless in future they make two different battery systems one for the new cars and another separate battery system for the retrofits they are locked into using battery packs that always will be compatible with their older cars.
Meh. The sales volumes on the early roadsters was low enough that they probably do better by just using the exact same pack design and sourcing more 18650 batteries. I doubt the situation with the current Model S is dramatically different. If you are a relatively young and ambitious company investing in a big new battery plant, your primary interest is unlikely to be optimizing the economics of maintaining your old designs, you are going to be focused on future opportunities.
The reasons they didn't make a huge jump seem pretty obvious to me. Cell cooling is clearly really important. Significantly larger cell diameters are going to have lower surface/volume ratios and longer distances for heat transfer. Significantly longer cells are either going to result in a higher riding car or need to be oriented horizontally, rather than vertically. I'm not sure if there is a problem with horizontal orientation, but I'm pretty sure that a good structural engineer can make good use of a bunch vertical metal cylinders to enhance the vertical rigidity of a box like, say, a battery pack case (doesn't appear that its part of the existing design though).
As for big pouch cells, well, yes, they could simplify some things, like cooling paths, but they have their own tradeoffs. They might be slightly lighter but less than you might thing, since much of the weight of an 18650 (or similar) is in the electrochemical components, not the relatively thin metal can. Whatever weight savings you gain though comes with a reduction of structural strength, which could be an issue for both pack design (see above), but also quality control during manufacturing. The metal coat of 18650 cells have a coat that protects them during pack manufacturing, while pouch cells are much more vulnerable. Accidental damage in during pack assembly was apparently an issue when pouch cells started getting more use in (some) laptops.
