scrambler
Hi, I am fairly new here, but I have been a regular reader of the forum for a while now, learning from the bests to educate myself on eBikes. I do plan to build or acquire/customize a high performance eBike in the near future.
THE TOOL:
Being interested in getting a productive pedal assist mode up to the max legal speed of 28mph, I needed to find out the pedaling cadence at every speed of existing bikes, as well as how to configure any customization for optimal pedal assist on a wide range of speeds (and optimal motor rpm on mid drives)
So I decided to build a simulator in Excel (file download below) to help with that.
To be sure to always get the latest version use the download location below.
https://onedrive.live.com/redir?resid=4BE668230430EFDD!1111&authkey=!AOdx1YqUZkbO44M&ithint=folder%2cxlsx
In case there is a problem with the download location, there is a local copy at the bottom of the post (I will try to keep it up to date...)
The Excel file contains 3 sheets.
Rear Hubs:
lets you specify a number of variables for a rear hub motor bike, like rim & tire size, Rear gears, Bottom Bracket gears, sprocket and chainring teeth numbers….
It computes in real time the rpm at every level of the transmission; wheel, sprocket, chainring and crank (pedaling cadence), and that for 9 different speeds (as well as any custom speed you want). You can also select any gear you want (front and back), for any of the speeds, to see the influence on the pedaling cadence.
Playing with the variables, you can visualize the pedaling cadence at any speed for any given configuration, and optimize sprocket and chainring values.
Mid Drives:
Similar to the above, but adds the transmission elements between the motor and the chainring, including the motor internal reduction ratio.
As a result, in addition to visualizing and optimizing the pedaling cadence, you can also visualize and optimize the rpm range of the mid drive motor.
References:
Includes some articles and reference sites I found useful during my research.
I would be happy to add more configurations to it if any one needs.
I don’t know if it can help anyone else but I thought it could not hurt to share. If it has already been done, I apologize for wasting your time
All this is still fairly new to me, so feel free to point out any flaws with the concept, or issues with the tool.
Thank you to the community for being such a great source of information!
EDIT (sept 14th): Added a second mid drive configuration.
The two mid drive configurations now are
Mid Drive configuration ONE: One chain between motor and crank, one chain between crank and rear wheel
You can set the following: Rear sprocket/gears; Chainring linked to the rear; Chainring linked to the motor; Motor sprocket and internal gear ratio
Mid drive configuration TWO: One chain between crank BB and motor, one chain between motor and rear wheel
You can set the following: Rear Sprocket; Motor Sprocket linked to rear; Motor sprocket linked to BB; BB Chainring; BB gears; Motor internal gear ratio
THE TOOL:
Rear Hubs:
Mid Drives:
References:
