yawstick
I guess I should preface this by saying that for the time being I'm pretty much sticking with the RC outrunner RC ESC route for the dirt bike conversion and there there will be no pedals to assist in starting. I have a beefy 300 amp 20 s ESC with sensor capability.... and the 12080 and 8085 and 6374 motors in transit. I didn't see the posts about the 12080 variants being prone to overheating due to what I think was described as induction heating of the magnets in the outrunner part.until after I had ordered them. So I may end up with two 8085 motors on the dirt bike and should have plenty to do soon.
Long ago I had an ultralight that had a torque converter of sorts on it and with luck hopefully I can round these up as I actually had two of them. This plane had a snow mobile type engine on it with a HTD type belt reduction to drive a relatively large prop at low speed. The device was in the hub of the large pulley. I think the hub was an off the shelf device bolted to the pulley. Inside the hub which had bearings on each side and was hollow inside. There was a wavy plate inside that was attached to the output shaft which passed through the bearings and the hub. Inside the hub there was lead shot which was slung to the perimeter and would lock up the wavy plate at some designed speed. This could be adjusted to some degree by the amount of shot inside. The shot was fairly fine... about the consistency of sand.
It just came to me after reading some of the posts concerning the effectiveness of sensored ESC type drive low speed starting on outrunner type motors that I may need more than a sensored drive to start a pedal less bike effectively. In the meantime I'll see if I can round those things up.
