dougnutz
- Joined
- Oct 27, 2010
- Messages
- 138
OK,Maybe rebuild would more appropriate. This is my commuter:
2004 is Trek Fuel , it handles very well at 37mph (down hills).It has a 9c 2806 20amp kit from Ebike.ca. The battery is a little small but it has served well for the first year. There is a longer story there but after 3000 miles it’s time to upgrade.
My needs: are similar to a lot of commuters, I pedal a lot and I usually use about 4-5ah on a 16 mile round trip, daily. 14 miles are on bike trails but one half mile of my commute is on a pretty busy road with a posted 35mph speed limit. Most people go 40mph. On the current setup I can manage 33 pedaling at a sprint but I’m finding this just isn’t enough to take the lane and the shoulder is rough and full of debris. So my plan is to join the 40 mph club. No pedaling is the preferred option at that speed.
After much lamenting about Lipo I finally decided to pull the trigger and move over to the dark side.
Santa came early this year and brought me these. 6s 8ah nano tech I plan to series them. 8ah should give me capacity to spare.
I also got a set of Methods fabulous hvc/lvc boards.
I purchased an Imax balance charger. It’s only 5amp charge rate but I don’t need fast charging. Besides it’s mainly going to be used for the occasional balance if my cell meter tells me they need balanced
I also ordered up a charger for bulk charging; which I plan to do most of the time. It has been preset to 74.4 v (4.13v per cell) This is where I am a little nervous. Based on other threads and my Life charger, this seems like a safe setup. I also plan to use the HVC boards to shut down the charger if a cell goes too high. Though I haven’t worked out exactly how I am going to do that yet (looking for advice here).
Lastly I purchased the 12 x 4110 MOSFET Extreme Modder Controller LYEN Edition.
Which I plan to set to 25 amps for starters then sneak up on 35 amps later. Since my plan is to change the controller out first setting the amp limit to 25 will keep the bms on my current pack from tripping.
I expect to upgrade the torque plate to be a pinch bolt style, as I do the controller change. I’m hoping to be able to run 30-35 amps without worrying about phase wire upgrades or heat. I will only be sprinting to 40 mph twice on the commute (once each way) and on flat ground. I need to try to make this bike as reliable as possible since it’s my daily transit. I do plan to buy another hub and transfer all the take-off parts to a second bike, but that may have to wait a little while.
I'm looking for advice and warnings. I plan to document all my conversion steps as I go so it will essentially be a build/rebuild thread for a commuter bike.
