hermes127 said:
Hi, thank you so much for your fast response! Usually for short distances I use street mode ("street mode enabled on startup" legal way 25km/h and 250W torque mode) because I have just to turn on the bike and it's ready to go, but for long distances (5-10 km) I prefer cadence mode and off-road enabled (500W 35km/h) because it's more relaxing, I have just to move the pedals...the only problem in cadence mode is that when you go slow or when you start the motor is not progressive and it's a little bit "nervous" (just a small movement of the pedals and motor kick in) that's why I want to use the brake sensors for having more control. Another thing that is a little bit annoying (and this is not a critic but a suggestion for future improvements) is the fact that I have to enable off-road mode and then cadence mode...is there a way to put a setting option for enabling both options in one preset so I have only to enable one thing? I can understand if is not possible but if it's something easy to implement I thing it could be a useful improvement. Have a nice day and thanks again for your work!
I am surprised that someone uses cadence mode, I have always considered it an emergency mode, in case of failure of the torque sensor.
The same for the torque mode, in case of cadence sensor failure.
If you haven't tried it yet, try the hybrid mode, it's for those who want to make little effort. And set "Street power limit" to 500W.
With the proper assistance parameters (levels), you will not return to cadence mode.
