Torque, moment, or moment of force (see the terminology below) is the tendency of a force to rotate an object about an axis,[1] fulcrum, or pivot. Just as a force is a push or a pull, a torque can be thought of as a twist to an object. Mathematically, torque is defined as the cross product of the lever-arm distance vector and the force vector, which tends to produce rotation.
Loosely speaking, torque is a measure of the turning force on an object such as a bolt or a flywheel. For example, pushing or pulling the handle of a wrench connected to a nut or bolt produces a torque (turning force) that loosens or tightens the nut or bolt.
Thrust is a reaction force described quantitatively by Newton's second and third laws. When a system expels or accelerates mass in one direction, the accelerated mass will cause a force of equal magnitude but opposite direction on that system.[1] The force applied on a surface in a direction perpendicular or normal to the surface is called thrust. Force, and thus thrust, is measured in the International System of Units (SI) as the newton (symbol: N), and represents the amount needed to accelerate 1 kilogram of mass at the rate of 1 metre per second squared.
torque is not the correct term, but thrust by it's self is not descriptive enough.
I just want to see a larger picture of E-Motion's avatar picture. or the finished gear box from the thread above. it should be listed on the Wiki, but I don't see it. seems like this should be available as a simple factory made device by now.
