TexasElectric
- Joined
- Feb 18, 2017
- Messages
- 3
Hi,
I see a lot of YouTube videos and manufactures talk about the "watt hours" of their electric scooters/eBikes batteries.
If I have a 48v electric motor and I use 200 watts in one hour. Am I correct in saying that I would need a 4.17 amp hour battery? (4.17 amps * 48 volts = 200 watts?)
So here's my thought... I am an avid cyclist. I own, what's called a power meter. Power meters for bicycles are strain gauges that calculate the amount of torque the rider is applying based on cadence (rpm) of pedaling and the "strain" or flex on the power meter. These power meters are generally expensive ($xxx to $x,xxx) and very accurate.
With that being said... When I am riding down a flat road I can average 175-225 watts and maintain 18mph.
Can I assume (in a perfect world not taking into account mechanical and electrical efficiency losses) that if I want an electric motor to power me along at 18mph, using 200 watts of power; a 48v motor receiving 4.17 amps for 1 hour should do the trick?
Thank you, and I appreciate and feed back from you guys.
