charlesv842
- Joined
- Mar 19, 2015
- Messages
- 21
Is it safe to run 24 volts through a 36 volt system? What about controller?
slcpunk said:........ the SW900 controller has a setting for voltage - can I use that to set it to 36V and get lower power and maybe longer battery life? the thing is so powerful, I really want to slow it down!.....
Drunkskunk said:slcpunk said:........ the SW900 controller has a setting for voltage - can I use that to set it to 36V and get lower power and maybe longer battery life? the thing is so powerful, I really want to slow it down!.....
Nope. setting the controller for 36v will only reset the low voltage cutoff from 40-ish volts to 30 volts. Doing that with a 48 volt battery is a good way to destroy it.
Instead, you can set the power with that SW900. If you're on pedal assist, and already on PAS 1, you can set the PAS sensitivity and the PAS start strength lower.You can also set your magnet type. If this setting is accurate, then a higher count will make the controller think you are pedaling slower.
If you're using the throttle, you can set the current limiting lower. I think default is 12a, which is very low. The range is 1 to 20a.
Instructions can be found here:
LCD-SW900 INSTRUCTIONS
