sl33py
Hey all!
I've been lurking for a while and having trouble deciding on an ESC. Would love to get VESC, but seems like it may be a while? My SMD soldering skills suck or i'd build my own. Between the ESC and programmer - just a bit out of my skillset.
Target is 8s, but may want to setup 6s for my GF to ride slower w/ me (likely will have 2 boards setup). I'd like mine to be dual motors (i have 2 pairs/sets, one DIY 5065 200kv, other 6364 200kv), and "extra" board likely will be for her to ride with me.
I guess my criteria are this:
8s capable (at least for mine), but would love to stick with same ESC for swap/x-compatibility between boards. Otherwise hers 6s single motor likely.
slow speed friendly - it will only take one jerky start/crash and she'll likely never ride w/ me again. Smooth and easy is the key. I'd like to avoid having to kick start if she doesn't want to.
Good brakes and too much to ask for regen braking?
I've been looking at the following
APS 120a twin ESC (says 2-8s, but actually doesn't do 33.6, max is 32v - Bruno has been great!)
APS 150a twin ESC (might even go sensored if that would help? (and add a hall sensor))
DIY/Torqueboards 12a 120a HV Opto - Speaking with Dexter (super helpful!) my only concern is slow speed and "require an initial kick to run good. I'd recommend kicking off anyhow as it helps with balance ..." (I understand but honestly if it isn't smooth and she crashes i likely will lose my GF as a skate partner. Has to be fun and easy for her, she's not very adventurous to begin with.)
Others i'm considering -
CC Mamba XL2
Turnigy Trackstar 1/5th Scale Sensorless 200amp 8s Opto Car ESC
Not sure if the APS do regen braking, or any of the others actually? Dexter says his Torqueboards 120a does.
I'm ok adding some hall sensors if that will give me good slow speed. Wouldn't mind avoiding if possible just w/ it being another failure point and hard to protect w/ a bare motor(s).
Which ones would you recommend? Especially curious how it works given the above criteria.
Thx for help pointing me in the right direction!
Rob
CC Mamba XL2
Rob
