Mr. Mik
- Joined
- Sep 3, 2008
- Messages
- 390
Puppyjump said:Maybe each 30 AH Vectrix cell is really three 10 AH cells in parallel? It's one possibility I can think of, assuming the 10 AH limit is truly correct. True, the diagram shows individual 30 AH cells, but it might be more of a conceptual block diagram as opposed to a schematic. Can you find a close-up photo of one of the cells? There appears to be 3 connections on top of each one that might correspond to 3 "D" cells inside each square cell package, but it would seem wasteful to package 3 "D" cells in an enclosure instead of just strapping them together and soldering a buss bar across them. Maybe they tweaked the chemistry just enough to avoid the patent? I'm very curious now.
Do you know much does that pack costs?
I have tested and reconditioned each cell in that pack; I made the diagram myself and it is correct. Each of the 102 cells has a voltage of 1.25V and the good ones have about 27Ah capacity (at 20A to 1.1V cutoff).
Deteails there: viewtopic.php?f=14&t=6277
The "third" connection in the middle of each cell is actually a valve to relieve extreme pressure if needed.
I do not know how much they cost - but have heard numbers from US$5000 to over US$7000.-
No-one has bought one separately so far AFAIK, but many have been replaced under warranty.
There might be a large number of Vectrix batteries still standing around and waiting for a sales boom....Vectrix Corp. had some dramas with additional Tax fines because of large numbers of unsold NiMH battery packs, and I think they also had to re-negotiate about the large number of packs they had agreed to buy from GP later on (those have probably not been built). Search for Vectrix shareholder reports from 2007 and 2008 for details.
