thedarlington
very nice evolution the projects had, too bad its so intricate id be scared to solder one of these but awesome job you all are doing
chenwood said:How important is it to heat sink the shunts?
I've got 24 cells with a 720W charger.
I mounted some caps on the bottom. I can't fit the board in the case with the shunts touching. I hadn't thought to install the shunt resistors to compensate.
Thanks.
Already sorted. I found a batch of replacement green/red LEDs on ebay. They're a bit cheap and nasty, but I've installed one and it's doing its job - red is back.fechter said:OK, good you found the problem with the red LED. Easy enough to fix that.
I'm not bothered about whether the LEDs light, I thought that they were indicating when a given cell had reached the 3.6V 'full charge' point it's been given, and that therefore they would all be lit by the time it switched off. Since this isn't important, I've dialed the pot a couple of hundred ohms to the right again.fechter said:If you like seeing the cell LEDs light up, you can crank the charger voltage up slightly. As long as the cells are reaching the set point, the LEDs don't really need to light up. This would indicate all the cells are well balanced. If an imbalance occurred, you would see the high cells light up.
Yes, I'm very happy with it. After a ten mile spin, I'm fully recharged again in just under an hour (at 9A with my EMC-900). Under my old regime it would take about 4 hours!fechter said:It sounds like you have it pretty close to dialed in now. The fact that it doesn't get buring hot at end of charge is very good also.
Zenid said:One slightly unnerving thing I've noticed with the pot setting though: With each cycle, it seems that the pot needs turning further and further round to the right to make switch off at the right time. Could this just be the Lithium cells "bedding in" - something to do with cell chemistry or whatnot, or is there some other explanation for this oddity? Like you say it's important that they don't stay on, as they unit gets quite hot at the end of a charge if they do (like when the pot is set too low).
steveo said:Can anyone please advise what voltage should be set on my charger for a 24s lipo battery
100.8v???
I had my psu set to that and the led is remaing orange green colour, also all shunt channels are light up
Also does the jumper plug need to be on the bms board, or is it only plugged in for testing?
Thanks
Steveo
fechter said:The EOC disable jumper is only installed for testing. Normally it is removed.
100.8v should be about right for the voltage.
The LED only goes red during HVC activation. You can test this by shorting the HVC line when the circuit is on.
fechter said:You should probably try testing the shut voltages without cells attached. Using a light bulb in series with your supply, you should be able to light up a portion of the shunts (bypass the control circuit). If you go back a few pages, you can see the diagram I made for Zenid. When the shunt LEDs are partially lit, measure the voltage across each one to make sure it's in the right range.
No heat indicates the cells are not up to the shunt voltage. You could probably increase the charger voltage slightly. No heat is really one of the design features we worked hard to get. A little heat would be ideal. If the shunt voltages are set too high for some reason, this could also explain it.
Sounds like you have the control circuit working OK.
fechter said:Looks like the shut activation voltages are in the right ballpark.
The cells should not be going over this voltage by any significant amount, so I'm not sure what's going on there.
You can sometimes have enough voltage drop in the tap wires to make a difference, but this would only be at full current. Measuring on the board connections vs. the cell end of the wires should largely eliminate this.
It almost sounds like the BD136 transistors are not turning on. It's pretty confusing which way to install them, so they could possibly be backwards. The schematic and datasheet would be one way to double check this.
Another test would be to use your light bulb setup but only feed a portion of the cells so that there will be more current available. If the cells are going significantly over 4.15v it indicates a problem. A current limited bench power supply is really the best way to test this.
steveo said:Bd136 is backwards!, good call, on my board the writing on the transistor is visable, on the photo on the instruction it is not, crap... Not looking forward to takin those things out gahhhh
This should be outlind in the instructions!
Ill let u know what happens
Thanks
Steveo
Zeropointbug said:I haven't looked through his whole thread, so I was wondering what cell count is your BMS designs? Would I be able to purchase one now, or the circuit board and build it myself?
I have a 16s A123 15Ah pack (51V)
Thanks
Zeropointbug said:SO, if I don't want to run the BMS when running bike (to controller), and only when charging, this would be okay, correct? (Cell_man's 30A BMS)
I think that is a "how long is a piece of string" question. Due to his provider going belly up with no warning Gary has to rewrite his site......intoworldsofuncertainty said:Hi,
I'm interested in purchasing a "Zephyr" BMS printed circuit board but have found the tppacks website to be under construction. Does anyone know when it will be back on-line?
cheers!
Gregb said:I think that is a "how long is a piece of string" question. Due to his provider going belly up with no warning Gary has to rewrite his site......intoworldsofuncertainty said:Hi,
cheers!
