Sevcon 75-7 Wiring Harness - Pilot Production
Postby methods » Mon May 29, 2017 1:25 pm
If you have been following we have taken an interest in the Sevcon Gen 4. Here are some pics of pilot production on a harness aimed at the 75-7 motor.
mmmm... the Sevcon. We are becoming very familiar with it. Those two came in from an enthusiast in the East Bay who has built a DIY motorcycle. You can see at least one of them came from a Euro-spec Zero as it has the homologation aluminum tape on it. Those are the donor orgrans we are using for the hardware decompile.
We cranked out one harness for a demo and now we are doing a run of 5. In the background you can see some other projects we are working on including integration of the Clear View for another enthusiast who has several projects in the works. We are lucky in that others are busy and we are tooled up so we get the opportunity to familiarize with costs offset. We are starting to see equipment coming in from the field in need of repair, retrofit, and upgrade. The BMS we are working on will support the Zero cell boxes as well as cell counts down to 4S for Lead Acid replacement efforts (complete with Hard LVC).
We have taken the following approach:
Encoder: We are maintaining plug and play compatibility with the 75-7 Motor Delphi connector. (I do not care for this connector series)
Contactor: We are maintaining plug and play compatibility with the Weather Pack connectors. (I do not care for this connector series, but they come in pigtails)
User Interface: We bring all of the user interface out to a 12 pin Amphenal AT series (which I REALLY like)
* Key-On - 2 wires fused to ring terminal battery side
* Enable - 1 wire referenced to Switch Ground (interlock in the powered up state - wired to an Estop on the bench and a switch in the throttle for the field)
* Throttle - 3 wires with a home run on ground
* Fwd/Rev - 2 wires referencing Switch Ground (Center position doubles as second interlock with a SPDT)
* Profile B/1/2 - 2 wires referencing Switch Ground (Base, Profile 1, Profile 2 using a SPDT)
* CAN - 3 wires with a home run on ground to a standard DB9
* Sevcon Clear View - TBD, have to read up on the interface
* Switch ground - 1 wire (REQUIRED - as Vbat/2 is supplied to these switches and you dont want that current on your throttle ground)
So the idea is that we can build ahead on a "shorty harness" which does not address specific user requirements on length and accessories. This drives down cost and lead time. The 12pin AT connector can be supplied pigtailed out or turn key to match specific customer needs on length and connectors for all of the above.
We are still working out details on which features to bring out and which to leave... so if you have requests make them known and we will accommodate where reasonable.
Price on these wont be competitive with OEM offerings as Engineering hours are being spent in their development. We hope to bring volume up to a point where we can offer these at a reasonable price to enthusiasts. We have ALL been waiting for Zero Motorcycles to release their "Power System"... but years into this wait... we still are not seeing it. I have had people drive from all over the state looking to secure one of these systems and what they are faced with is the option of buying an entire bike, scraping the bike, and utilizing the Battery, Controller, MBB, etc.
Trouble with this is that the Zero harness is quite complex... The MBB is integrated and not open source...
Really most of our requests are from people who can handle aux requirements like lighting... they are not running ABS or any sort of advanced requirements. A simple CA on the handlebars, control over the Sevcon, and a clean harness is the ticket to success.
As for batteries... look out in the next 3 months as I saw something VERY JUICY in the works a couple days ago. We all have a hard-on for the Zero Cell Boxes but they are still near impossible to find... and even with dealer status it is difficult to procure the BMS, harness, and contactor to outfit them properly. In-Production parts can be had... but all legacy gear is being held tight by Zero in order to service fielded items (so - good luck buying new-old stock... ain't going to happen)
Its a shame that we are having to grind this out from the ground up... but thats what you gotta do sometimes to get the ball rolling.
I will update this thread with pics as time allows for harness completion.
As with all efforts... early adopters drive the design... so it may not be the ultimate general solution... but it will meet customer requirements for the most part.
thanks,
-methods
Oil companies and Alkaline Battery companies are peas in a pod... find a way to put your foot in their ass
Protected 1S, 2S, 3S, and 4S rechargeable lithium packs should be on every store shelf in the world
It is not technology holdings us back... it is greedy profiteers holding us back. Point me in the right direction
methods
Re: Sevcon 75-7 Wiring Harness - Pilot Production
Postby Doctorbass » Thu Jun 01, 2017 12:53 am
methods wrote:If you have been following we have taken an interest in the Sevcon Gen 4. Here are some pics of pilot production on a harness aimed at the 75-7 motor.
thanks,
-methods
Hey Methods all of your great work will i'm sure help alot !!
btw i have here a monolith 11.4 ( a 2013 one) and few 2013 and 2014 brick and 3 working BMS from the 2013 and 2014 and also 2 of the 2012 BMS. Even If you develop independent BMS or communicating interface for these battery let me know!
all i know from now is that these BMS seem to enable with some SYSTEM ON signal loop to activate the BMs and maybe contactor and also THROTTLE ENABLE signal output when all cells are ok from teh BMS.
There is a nearly complete schematic of the Zero 2013 S you can get here:
http://zeromanual.com/index.php/File:ZeroWireDrawing_2013_S_11-4_R-1-3-0_no-grid_highRes.pdf
i also tried to identify all the wiring on te multipin connector of the 2013 but it is not confirmed:
This Unnoficial Zero manual that Burton made is well made!
Doc
Last edited by Doctorbass on Thu Jun 01, 2017 12:56 am, edited 1 time in total. View post history.
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewtopic.php?f=3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Doctorbass
Postby methods » Tue Jun 06, 2017 4:25 pm
Lessons from the Field:
Issue: Selection of assignment of DIO's on 35 pin connector
I knew I should have just followed some standard... but of course I followed my own... and ran into a hitch.
Sevcon ClearView... which is not easy to program without the password - even with backdoor access - has expectations about pin assignments
Each one is different - which tells me it IS programmable (as the documentation suggests) but... sigh... what I have in front of me is what I have
Lesson: We made all of our harnesses "shorty" - such that all the DIO and AIO comes out 12" to a 12pin connector
Turns out this was wise... as we can now just re-assign usage on the other side of the 12" and we dont have to re-pin the Sevcon (which you can do.... but causes wear and unreliability)
Another HUGE issue is when it comes time to test then ship a customers harness... each and every function must be tested and known good.
Each customer has a totally different setup
So... for now I am re-jigging my house harness (12pin out to Throttle, Regen, FWD, REV, Profile 1, Profile 2)
As standards settle I will just make one of each of the flavors which are most common
So - we lose some color coding but lose no time - other than the 24 crimps and cuts - that it takes for the harness
Nobody I respect ships a firmware system or harness without ACTUALLY TESTING IT as it will be used... so .. thats the cost of doing business.
When our product arrives it works, we know it works, so if it does not work... it is on the receiving end and not our end :wink:
As a small business man who has eaten losses more than a few times... I can tell you that nothing is more important than absolutely KNOWING that what you shipped to your customer is in perfect working order. Customers have an amazing ability to cast doubt and send you chasing your tail (which is totally natural). I learned from Justin @ Grin that the best defense is a good offense.
So - I am off to crimp some more pins while I wait for my knight in shining armor to appear
(Person who wants to crimp like a mad dog @ $20/hr with zero mistakes)
-methods
methods
Postby methods » Mon Jul 17, 2017 7:53 pm
We finished our first production run and worked out the little details.
A LOT of detail goes into the BOM of a cable... there are a thousand little details... and they add up in parts cost and time.
At this point I am pretty happy with lengths and procedures.
We have the harness decomposed down into bite size chunks that we can get produced outside if things scale.
I was considering going with Innerstep... a local turn-key shop that is actually on the same street as Zero. They did a lot of work on the pre 2012 bike batteries (assembly, not design) and I have a working relationship with their front end guys + their lead wire wizard. They have handled a job for us in the past and it went well. Big picture... they have contacts all over the bay... so if you dont like getting run through the mill you can go to them, spend a little engineering money, and they can leverage their volume and contacts to get you into a big shop.
If you have never tried to jump feet first into a big shop... eh... careful buddy. There are a THOUSAND ways to become sorry... and the price you pay is ENDLESS rework if the error was in your documentation. :idea:
Design reviews...
Pre-Production units...
Production Intent Builds...
Just giving stuff away to guys who will actually use it...
These are good ways to not fail hard.
-methods
methods
Return to E-Scooter and Motorcycle General Discussion
Who is online
Users browsing this forum: No registered users and 4 guests
