Kawasaki D-tracker Build
artvk   100 mW
Post by artvk » Feb 09 2020 12:01pm
Hi guys,
Im Art.
Im converted Kawasaki D-tracker 125 . Here is my newbie build thread. Welcome for all comments and suggestion.
Frame : Kawasaki D-tracker 125cc. (KLX frame)
Wheel : 17inch
Front sprocket : 11T , Rear sprocket :70T
Battery : 20S20P 72v50Ah newly Samsung 25R
BMS : Chinese bluetooth one
Motor : ME1304 Water-Cooled
Controller : Mobipus 72600 + wifi module
Throttle : Domino
DC-DC converter : 250W 20A
Im using nickel strip weld to copper sheet 0.2mm, laser-cut, in the photo.
Using Bakelite CNC machine for holding main busbar terminal
Left and right module have been isolated with polycarbonate
Here comes Aluminium case
Im 3D printed contactor,fuse, and precharge housing.
quick assembly for test run.
Im now working on pump and radiator fitting.
Art
SlowCo   100 kW
Re: Kawasaki D-tracker Build
Post by SlowCo » Feb 09 2020 6:27pm
Very nice work :thumb:
spinningmagnets   100 GW
Post by spinningmagnets » Feb 09 2020 6:31pm
Well done, sir!
boars   100 W
Post by boars » Feb 09 2020 8:18pm
Looking very tidy :D
I spy a rego tube, man they were all the rage here till the were ruled illegal and earned you a fine.
Thankfully not long after: rego stickers were no longer required and cops just looked up your rego off the plates instead.
What kind of tablet are you using by the way? waterproof or just going to ride on sunny days? :mrgreen:
I've been trying to find a good tablet/mount combo and I'm still looking... :(
macribs   1.21 GW
1.21 GW
Post by macribs » Feb 10 2020 1:28pm
Cool cool cool :thumb:
Velric   1 µW
Post by Velric » Feb 10 2020 5:31pm
Wow really cool, is that a pre made display? an Android phone or what? really curious about it.
Bernel   100 W
Post by Bernel » Feb 10 2020 6:04pm
Nice work. Good job.
shortcircuit911   1 kW
Post by shortcircuit911 » Feb 10 2020 8:16pm
Nice work.
Also interested in what tablet you're running. Mine won't fit all the info you have displayed (I'm running a 72200).
artvk   100 mW
Post by artvk » Feb 10 2020 10:20pm
boars wrote:
Feb 09 2020 8:18pm
Im using obsolete Dell Venue tablet, since the program is compatible with windows. It's not waterproof.
Im working on CAN bus output and will using CAN to display in CAN automotive display, maybe AEM Digital Dash.
Art
artvk   100 mW
Post by artvk » Feb 10 2020 10:22pm
shortcircuit911 wrote:
Feb 10 2020 8:16pm
Nice work.
I use Dell Venue tablet. The Mobipus 72200 can send data to tablet by using their extra wifi module.
Art
artvk   100 mW
Post by artvk » Feb 10 2020 10:26pm
Velric wrote:
Feb 10 2020 5:31pm
The controller have extra wifi module that able to link to Windows based device.
As I checked, these 6-8 inch Windows tablet are all obsolete. Both Dell Venue and HP Stream 6-8" screen were all obsolete.
Art
brake034   1 W
Post by brake034 » Feb 11 2020 9:09pm
Nice work K. Art, where in Thailand are you located? I am in Chiang Rai.....
Frey brand ambassador.....
artvk   100 mW
Post by artvk » Feb 12 2020 11:58am
brake034 wrote:
Feb 11 2020 9:09pm
Im in Bangkok. :thumb:
Art
Post by shortcircuit911 » Feb 13 2020 11:57pm
Thanks for the info. I'm running the wifi module as well and have a tablet setup, but the aspect ratio isn't big enough to fit everything you have on yours. Might just pick a used one up from ebay.
artvk   100 mW
Post by artvk » Mar 09 2020 10:05am
Just have chance to do the dyno test.
Im testing 82v and 500Amp for turbo mode setup for this result hp and torque below.
Note* I'm matching rpm of motor with the dyno unit since it the rpm matching was not like combustion engine.
Art
tylerwatts   1 W
Post by tylerwatts » Mar 09 2020 6:24pm
Very nice output. What sprocket ratios are you using?
Cheers
Tyler
artvk   100 mW
Post by artvk » Mar 16 2020 6:56am
tylerwatts wrote:
Mar 09 2020 6:24pm
Cheers
Tyler
Front11T Rear70T
Art
artvk   100 mW
Post by artvk » Mar 25 2020 2:24am
some test ride with data logging
Art
