16S 320A ANT BMS balancing question
hasp
Hi everybody,
i am currently designing and building a litte 2meter long 4x4 transport car thingy with 2 friends:
there is a ongoing ES build thread to be found here: https://endless-sphere.com/forums/viewtopic.php?f=34&t=114477
We have currently finished the battery pack, it is a 16s 100Ah LiFePo4 Pack with a 320A ANT BMS,
like this gentleman tested and liked here:
[youtube]im4ggvoni5M[/youtube]
however it does not seem to balance while charging,
despite "start balancing" at 3.1V and "start balancing voltage diff" at 0.002V
any ideas ?
thanks a lot in advance!
cheers,
alex
Hi J,
our charger charges with 9.something volts in the lower of his 2 settings..
...so theoretically it should balance?
havent checked that yet, as the rest of the car wont be finished that soon and i didnt wanna store the battery fully charged for long... (because lifepo4)
You can start balancing manual.
I balanced my "used" 21S100Ah pack after assembling over four days without a charger attached to the battery.
My ANT started balancing only under 11A.
You would need an active balancer to achieve balance overnight.
If I recall, the balance limit on an ANT BMS is 200mA, assuming your board was well built.
