Sabvoton 72150 + H6 Display -DO NOT PURCHASE
Jonno
Hi Guys,
I have received 3 x sabvoton 72150 + H6 displays in kits with QS205 back and from wheels.
After very easy builds and setups I have found the following problem:
The PAS side of the controller works fine with 5 adjustable assists and power/speed settings.
HOWEVER the throttle side of the system is defaulted to so called max power. You cannot adjust this even using the latest software. The throttle remains live and with full power output even when the pas is on zero on the H6 unlike the UKC1 display version which alters the the throttle power accordingly.
I have spoken to SIAecosys about this and they say they make it clear on the adverts throttle and the pas are not linked- well I've yet to find this.
They also state that you cannot add a three position switch and add that this model controller is built especially for the H6 display. So all in all it's pants as a kit.
Having waited 21 days for this response has left me somewhat annoyed and $1200 out of pocket as I now have to replace these3 controllers with something far less DANGEROUS.
Any ideas?
Jonno
