Hi guys,
I am running a 1500W setup (KT-LCD 3) with a 48V/60V controller and a 52V 20Ah battery. The problem I am experiencing is that for some reason the battery-low threshold at setting C14 (=0 already) kicks in and the motor shuts down (with battery flashing on screen) at around 48V. But this is a 52V battery, it should go down to 44 or so. I think the problem may be that the controller treats it as a 60V setup, which would explain the cut-out at 48. Does anyone know of a solution for this problem or have I just wasted some money on an incompatible battery? Many thanks !!
