I have disabled the v3.1 attachments in this post due to the errors in this earlier version but left this post up for reference. Latest v3.2 sheets available in post further down the page. Direct link to new post with latest version:
http://endless-sphere.com/forums/viewtopic.php?f=30&t=59409#p890297
I've also almost got motor/e-bike sim. sheets that are "good enough" (as in not perfect but close enough I'm willing to share). These are the first one that I've got up to date and am ready to post. More will follow (Crank-Drive comes next)
Motor Only Simulator v3.1:
ElecMotSim3.1.xls
Basic Instructions:
----- This is just the bare motor only simulator I am currently using as the "core" of my e-bike simulator sheets.
----- All user adjustable input fields are in
red colored lettering and often have explanations and/or instructions below them.
----- Accuracy is not guaranteed, I'm pretty sure this version is more accurate then previous versions of motor sims. I've used as the core of my e-bike calc. sheets but I'm also sure it isn't totally accurate by any means. Also I don't do near as good of job of "show your work" as Crossbreak does and if I were a betting man I'd bet his actual motor sim. is probably better then mine.
Left Drive E-bike Simulator v3.1:
Full Band Left Drive Calculator for E-bikes v3.1.xls
Basic Instructions:
----- The intended purpose of the sheet is to model performance and assist in choice of gearing ratios for a "Left Drive" type e-bike where the motor drives the left side of the rear drive wheel on its own reduction separate from the human pedal drive on the right side which is left normal bicycle style.
----- The first sheet labeled "Left Drive" is the display sheet where you see what it can do after you put in everything else.
----- The last sheet labeled "The Basement" is where all the calc. grids are that crunch the numbers, unless you know what your doing probably don't want to mess with anything on that sheet.
----- All the middle sheets are where you put in stuff about you and your bike and its motor and battery and all that.
----- There is a build already put in, its one I want to build myself. Change the inputs to suit your needs. Your probably going to need too because my build that is in it is not a normal e-bike build but rather a pocket-rocket type folding e-bike build with a small fat rear wheel. I do intend to use a GNG small block type motor only in left drive configuration so you should be able to keep some of the motor inputs at least if your running a 48+V system and are using that motor for your build as well.
And a very big thank you to Crossbreak as well who taught me how to figure out how to include inductance into my motor modeling sheet. Whatever he gained from me I think I gained even more from him. So lets shift the credit that direction !!!
Please note my motor simulator that serves as the "core" of my sheet (in my sheets the motor sim is the means to the end not the end) is not exactly the same as his although they are similar to each other.
