rebelpilot
Project
I need to build a charger/balancer for 12 packs of Zippy 6S 5Ah 25C Lipo.
Background
I was down in the basement today assembling a parts kit to build a charge controller based on the meanwell charge controller design, and a balancer based on the 12s CellLog CMS-Balancer design. But I got distracted.
I came across four pieces of GPIB equipment I salvaged from old production line testers. I tried selling this stuff online years ago, I had no immediate needs for the equipment and the manuals were very expensive to purchase at that time.
I decided to check if the information was now available. I was able to download user, service, and programming manuals for each piece of equipment.
I have two National Instruments GPIB-PCIIA cards, and an old computer with an ISA bus, but I have been unable to communicate with the cards.
Plan
The current plan is to buy a Prologix GPIB-USB Controller and use EZGPIB to run the system from an old laptop.
http://prologix.biz/
http://www.ulrich-bangert.de/html/downloads.html
The system would consist of two the 20V power supplies connected in series to charge all 12 lipo packs in parallel. The individual cells would be monitored with the 3457A multimeter and resistors would be switched in via the 3488A controller to balance the cells. I have to do some more reading, but I think the 3488A may be able to run the system once it is debugged.
Charge voltage 4.15V/cell
Charge current 50A
Balancing shunt resistor value TBD
Charge termination current TBD
I need help.
Questions:
Is there a better GPIB-PC interface option?
Any alternative software suggestions?
Is this a viable plan?
What balancing shunt resistor value would work, how is it calculated?
What charge termination current would be suitable for 6 packs or 12 packs in parallel?
Any suggestions are welcome.
Equipment Descriptions:
3488A Switch/control unit
The Agilent 3488A switch/control unit brings versatile, GPIB programmable switching to tests requiring multi-channel measurements. The Agilent 3488A provides signal switching with the integrity and isolation needed for high-performance production test systems. It also offers a flexible, low-cost interconnection for automating experiments on the bench and for developing tests in the lab. The Agilent 3488A is designed to hold up to five of the following switch and control modules:
• DC to 26.5 GHz signal switching
• Up to 50 channels
• Matrix, multiplexer, and general purpose relays
• 40 configuration storage registers
• Digital I/O control and actuation
• 11 switch and control modules
General Purpose Relay (Option 011/HP 44471A) (I have three)
This module consists of 10 SPST independent relays for general signal switching and control of external devices.
Quality connections make this module ideal for switching signals when multiplexing is not required, or for supplying switchable power to the device under test.
Input Characteristics
Maximum Voltage (terminal-terminal or terminal-chassis): 250 V dc, 250 Vac rms, 350 Vac peak
Maximum Current: 2A dc, 2 A ac rms
Maximum Power: 60 W dc, 500 VA ac
Thermal Offset: < 3,μV
DC Isolation (40ºC, 60% RH)
Channel-channel, open channel: >10^11 ohm
AC Isolation/Performance
(50 ohm termination) 100 kHz 1 MHz 10 MHz
Insertion Loss (dB) <0.30 <0.35 <0.90
Crosstalk (dB) <-73 <-53 <-33
Agilent HP 3457A. Multimeter
Seven functions with 3 1/2 to 6 1/2-digits of resolution extendable to 7 1/2-digits at reading rates from 1 reading per every 2 seconds to 1350 readings per second, and DC volts accuracy as good as 5 ppm.
Ten channels with the 44492A plug-in multiplexer assembly.
Measures DC Volts & Current, Resistance, True RMS AC Volts & Current, Frequency & Period.
Also performs the following math functions: Null, Scale, Offset, RMS Filter, Single Pole Filter, Thermistor Linearization, dB, dBm, % Error, Pass/Fail Limit Testing, and Statistics.
HP6031A Autoranging 1000W GPIB Power Supply
Output Ratings
Voltage: 0 to 20 V
Current: 0 to 120 A
Autoranging:
20V, 50A
14V, 76A
7V, 120A
Programming resolution
Voltage 5mV
Current 30mA
Programming Accuracy at 25°C ±5°C
Voltage: 0.035%, +15 mV
Current: 0.25%, +250 mA
Ripple & Noise 20 Hz to 20 MHz
Voltage rms: 8 mV
Voltage Peak-to-Peak: 50 mV
Current rms: 120 mA
Readback Accuracy at 25°C ±5°C
Voltage: 0.08%, +7 mV
Current: 0.4%, +100 mA
Load regulation
Voltage 3mV
Current 15mA
AC Input Current
24A @ 120Vac
14A @ 240Vac
Weight
38lb (16.75” x 5.25” x 20.33”)
Xantrex XKW 1 kW programmable DC power supply
High frequency conventional PWM switching supply
Constant voltage with automatic crossover and mode indication
Parallel or series connection
External shutdown, external indicator signals
Remote/local modes
Remote sense, 1 V line loss compensation
Analog programming
LabVIEW® driver
Over voltage protection
Current limit
Over temperature protection
GPIB interface card
Isolated interface card (ISOL)
Note: The XKW Series is not available for purchase in the US.(I think it’s sold as Sorenson in the US)
Output Ratings
Voltage: 0 to 20 V
Current: 0 to 50 A
Voltage 5mV
Current 30mA
Voltage rms: 5 mV
Voltage Peak-to-Peak: 60 mV
Load regulation
Voltage 3mV
Current 5mA
Operational AC input voltage
200-250 VAC at 26 A rms 1-phase, or 100-130 VAC at 20 A rms 1-phase, 47-63 Hz (That has to be backwards doesn’t it?)
Weight
18lb (1.7” x 19” x 17.5”)
Background
Plan
Charge current 50A
I need help.
Questions:
• Up to 50 channels
Output Ratings
Voltage: 0 to 20 V
Current: 0 to 120 A
Autoranging:
20V, 50A
14V, 76A
7V, 120A
Voltage 5mV
Current 30mA
Voltage rms: 8 mV
Current rms: 120 mA
Load regulation
Voltage 3mV
Current 15mA
AC Input Current
24A @ 120Vac
14A @ 240Vac
Weight
Remote/local modes
Analog programming
LabVIEW® driver
Current limit
GPIB interface card
Output Ratings
Voltage: 0 to 20 V
Current: 0 to 50 A
Voltage 5mV
Current 30mA
Voltage rms: 5 mV
Load regulation
Voltage 3mV
Current 5mA
Weight
