110A 30kV contactor
Doctorbass
Quebec, Canada East
:mrgreen:
Today i was searching for a switch/contactor able to hold 100A peak for my ebike and that can have contact for DC voltage like 100V.. not easy to find i admit!! :shock:
I finally found the LEV200 from Kilovac that is a great popular switch for EV.. but it cost around 130$..
Then i remembered that in one of my multiple electronic stored boxes that i had a strange switch.. or SCR made in porcelaine that had KILOVAC writed on it..
So i deciced to find what is the spec for it.. and i found that this great switch can handle 110A at .... i say: 30 000V :shock: :shock: and that at 30kV 30A it can switch to 32MHZ !!!! More than i need...
But the important thing in this story is that i solved my arcing switch problem!!!.. I completly welded 3 switch on my bike since it is at 100.8V :lol: ..
http://relays.tycoelectronics.com/datasheets/kc20_30.pdf the KC-20
NO MORE PROBLEME!!!! :mrgreen:
only 9 oz !! vaccum type!
and up to 30 000V.!!.. hummm.. ebike!!!.. 5305... ... ok..ok.. i'll keep 100.8V
but... it is writen that it's a "No Load Switching" type.. :| .. does it meanthat i can not carry current when changing the state of this relay?
Doc
Hmm...If I had to guess, I'd say it's not made for switching under load, ESPECIALLY since it's got copper contacts. I think the ones made for load switching are usually coated in silver oxide.(?)
FWIW, if you use a precharge resistor, I think it would be okay to use, since then it wouldn't have to deal with that huge current surge when the capacitors charge.
Ja Doc, don't switch under load... it could weld closed. As Link said, high power contactors use silver points and magnetic blowouts to reduce arcing. Precharge resistor is strongly suggested.
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=4611
