135x12 to 110x15 maxle
cheapcookie
Cheapcookie wants to swag out the aliexpress special.
the hub found on ali is 110x15 proclaimed, meant for travel forks obviously
how do I fit the beast on a 135x12 thru axle(rear obviously) ?
26x2.4 is the tire size on the mid travel dh bike
edit: sadly 2.4 largest tire in triangle possible
[ali link for documentation purposes]
[Alibaba "distributor/contact"]
[Overclocker]
[Uruguay]
Rear dropouts on Modern Mountain Bikes are 12 mm so you will need a machinist to make end caps that will also center the wheel and you will need to move the disc brake mount as well.
What frame do you have that is 10 mm x 135 mm ?
All the frames I have seen for MTB , ( unless they are for plus size tires or fat bike )
are 12 x 142 mm or 12 x 148 mm .
sorry made a mistake, this hub is 110x20. My rear hub is 135x12 thru axle.
I am talking to lmx see if their hub fits on 135x12 TA with spacers.
