2022 Kona Big Honzo Bafang BBS02 750W
Djabag
Sweden, Stockholm
2022 Kona Big Hozo 27,5 Boost, Bafang BBS02, PWC Dropper suspension post, SKS Germany Mudrocker mudgards
Magura MT5e with 203mm Magura discs. The brake power is amazing and the cut of switch in the levers has zero delay. IS mount on the frame.
DT Swiss HU 1900 Spline® 27,5" 35mm CL Boost Shimano HG . Max load 150kg and about 250USD for a pair. HU stands for Hybrid Utility and are designed for E bikes. The hubs are DT Swiss 370.
Shimano Linkglide groupset are made for E-bikes and durability. The shifting is not as fast as on regular Shimano groupset, but it not a problem.
48V 20Ah 21700 cells
BB is 96mm so you need a 100mm, with 10mm on the drive side and 20mm on the non drive side. Not ideal but it works.
The chain stay are not ideal, but if you want 2,6-2,8 tires it's has to be wide.
The chain line is perfect in the bottom half of the 11 speed cassette, Just where I to 99% is using it. But it works on all the cogs.
A life time companion..
Ergon Grips HIGO adapters from Magura 2 pin (red) to Bafang 3 pin (yellow).
Battery holder is on 3 Grin bottle bob's
