24fet controller with torn wires - need help restoring them
Noamsal
Israel
so i got this controller for a pretty good deal, its a 24fet controller up to 100v and gives 80a
it could be a greentime but im sceptic
anyway when i got it it looked like this
i have the throttle\phase\battrey wires but i also want to sort out the other wires
i managed to find the 3 speed switch, it was easy, but all the other ones are pretty tough to figure out
please help?
Definitely not a Greentime controller, whole different layout, yours has white PCB vs. green one from Greentime.
Looks like it´s mangled pretty good, sorry can´t help you with the wiring on this one, soldering job looks iffy as well.
Ok so i managed to do it
got all the wires i need - batt pos\neg, phases, halls, throttle, 3spd switch, and ignition
went for a test ride and it turns out the shunt mode the previous owner made gives 150 amps! i got to 60mph on a flat!
but i will take the shunt mod off to reduce the consumption
