25-40kW peak Electric Motor
drebikes
Spain
Hi guys,
I'm thinking of the possibility of modifying an existing vehicle to have it electric. I don't need a lot of power, the idea would be more that I want to prove that I can do it. Now, although I don't really know what I want to do, I've done some computations and think I might need a motor that does minimum 25kW and up to 40kW. I don't want to go too high as batteries become a bit expensive.
I've found various sellers that have even 48V motors that do 25kW+ like Parker. My question is weather you know various sellers that provide this king of power levels at voltages around the 48-96-max120V mark.
My finds so far:
*parker http://ph.parker.com/us/en/gvm-global-vehicle-motors-for-mobile-applications
*aswoods http://www.ashwoodselectricmotors.com/interior-permanent-magnet-motor
*yasa (could be more expensive) http://www.yasamotors.com/
*agni - they sell brushed motors, which I don't like / want at all (it is simportant for me to have a brushless)
I've listed British producers as I know them better having worked with some. I'm open to all ideas.
Hi, 25kW at 48V is pushing ~600A. Not sure of availability over there, but these guys can deliver. I have used their AC15 package and liked it. http://Www.hpevs.com
Thank you major, I am looking at their website.
It is a bizare rule in Europe that if one stays below 60V DC then homologation rules are quite a bit looser. I plan to stay below 60V DC (48V rated AC) if possible; likely I'll be over 100V...
FYI - You want to stay well away from AC motors. I've read that in the ev forums.
I can not find the specific post, but its in this forum diyelectriccar.com
I think perhaps maybe the controller might be an issue. I do clearly remember a member on that forum posting to stay well away from AC motors, the poster had thousands of posts so I'd assume they are knowledgable.
I cant find any backup info on that. Maybe its 3 phase AC, I dunno.
drebikes said:
Hi guys,
My finds so far:
Buy the hybrid version 75-7 motor from Zero. This is teh motor that was made for the 2012 motor patch.. these are 40kW 4 turn and usually made for 66V nominal. You can also use a controller that have the field weakening like the Sevcon, Sabvoton, golden motor, Kelly etc.. so you will run 48V and have the same rpm as a 70V battery would give you
Doc
The zero 75-7 looks great and I have some experience with sevcon inverters, also pretty good. I'm googling tech details, but not really making good progress, their website is all about the experience :evil: and not the numbers. If you have any links to tech data, power torque f(voltage) curves it would be awesome.
*EDIT: found this, reading through https://endless-sphere.com/forums/viewtopic.php?f=10&t=50367
