lionschasing
- Joined
- Jun 22, 2013
- Messages
- 48
Hello
I would like to upload my latest build. I am looking for some chain advice, I am thinking size 40 chain with suitable sprockets in a package for the motor shaft and rear tyre.
If anyone knows a supplier for a 60 tooth with a 30mm bore hole for 40 chain and 3/4" sprocket with 14teeth + chain or where to order them from I'd be very grateful if you could share this information, I've got a budget of $70 for these items
I attach a picture
Thie nice thing about this motor I picked up is that it is a fast wind and spins at 2000rpm at 24volts...so even at 48volts it will probably spin at 4000rpm with some parasitic losses, the motor is rated at 250AMps, I own a controller that can output 350A, and some amp20ah a123 cells in 16series configuration ready to slot in, built up the bms for them....everything's ready except for the plate, which I need to order from the welder's. I drew it up in autocad.
any advice on 'what you would do' would be very useful right now.
Best wishes
Ed
I attach a picture
Best wishes
Ed
