bobcourtney
I had to take apart a 36V 15Ah battery that I recently bought on ebay from daoji888 (http://cgi.ebay.com/36V-15AH-LiFePO4-Li-ion-Battery-Electric-Scooter-/290444225724?pt=LH_DefaultDomain_0&hash=item439fd32cbc#ht_3949wt_982) since I dropped it and sparks flew.........
Anyway, for reference the battery used in the pack is a China Bak Battery (http://www.bak.com.cn/pro_xiangxi.asp?id=794&bigclass=High-power%20battery%20cells) 26650MP-Fe .
It's a 2700 mAh battery with a rated 10A (3.7C) maximum continuous discharge current (see http://www.accu-by-seidel.de/WebRoot/Store15/Shops/61957196/4B05/6CA7/452C/7EB8/945C/C0A8/28BD/B355/26650MP-Fe-2700mAh.pdf).
Total of 72 cells wired in 6 cell parallel.
6P gives 6*(2.6-2.7Ah) = 15.6 to 16.2 Ah with a potential 60 A discharge rate. The BMS and wiring are pretty minimal with a 15 A nominal rating.
One of the cells got damaged by the drop and burned off the covering through a wiring short - the voltage on the damaged cell after the burn was 3.4 V so I guess it's ok.
The welded battery connectors were fried off the damaged cell as well which is hard to repair so I decided to leave the damaged cell unconnected.
The pack still comes in at 39.9 V after the fall.
A question to those in the know:
Am I going to run into any problems running the pack a cell down in one of the parallel series?
I suppose the 5p cell will discharge quicker but the BMS should cutout before it drops too much. Will I now have effectively a 5x2.7 Ah = 13.5Ah pack?
