e-electrics
- Joined
- Jun 16, 2022
- Messages
- 37
For sale used Jet Drive 80.
Surf fun without ocean and waves.
This jet drive is the perfect companion for your surfboard, paddleboat, kayak, canoe... The Jet 80 supplies extrem high maneuverability.
The advantages of the Jet 80 at a glance:
Nozzle, impeller, stator made of high-strength aluminum 7075
All parts black anodized for extra protection against corrosion
Flow optimized tunnel made of metal
Triple bearing and shaft seal (Simmerring)
Direct lubrication via grease nipple
Salt water resistant
Length: 320mm (12,6")
Height: 121mm (4,76")
Width: 130mm (5,12")
Weight: 1995g
Shaft: 12mm (0,47")
Impeller: 80mm (3,15") | Aluminium 7075
Static thrust: Bis 500N
Required rpm: 12.000 - 14.000
Min. required power: 7,5KW Current
Material: Aluminium 7075 | Tunel Metal
Cooling water nipple: M6
Jet drive which includes:
- Jet 80 | Booster Aluminium
- Aluminium Platform (50x14x13cm)
PRICE:350 EUR 200 EUR
Originally purchased from:
MHZ
Can be also purchase with with BLDC motor Lehner Torqstar 3, 24 KW, from 2 000-20 000 RPM, outrunner with water cooling in excellent condition. 5 windings, 20 Magnet Poles, 12mm shaft. Fully tested with VESC and ESC, used only for 3 hours. Custom industrial construction edition with ceramic bearings which are designed for 100,000 hours of operation, increased diameter tubes of water cooling for better heat sink, temperature sensor.
Comes with 6 month of warranty.
Shipping from EU by express courier service.
Price of the BLDC motor separately:650 EUR 400 EUR
Lehner
The BLDC motor includes:
- Motor Mounting.
- Coupler.
The price for the Jet Drive and BLDC motor with mountings is 600 EUR.
Weight: 1995g
Shaft: 12mm (0,47")
PRICE:
MHZ
Lehner
- Motor Mounting.
- Coupler.
