72v battery needed
Hello,
We still have three 72V22A ( BMS 40A ) batteries from our prototype that we no longer have a use for. Considering the motor's power, you would need two of them for optimal operation.
Dimensions(case): (WxLxH): 90x160x500mm
Production Year: est. Q2 2022
Price: 350$/unit
Shipping from EU
how pricey exactly? what kinda specs? would you be willing to use cells that i provide, and would that reduce the price or is it mostly labor?
the cells are 20Ah. 200amp continuous. very small form factor for the power they produce. i could do a 24s1p with a smart, active balance bms (preferably JK) for approximately 4 or 500. bump that to a 2p pack and youd be around 750 or so. ive attached the datasheet for your convenience.
to answer your question about using your cells....i wouldnt mind doing that but shipping back and forth could get expensive.
  • amp20m1hd.pdf
