countermeasure
1 W
A123 commercial division just dropped me an e-mail. A UPS size battery is available now. It's only 4.6Ah.
Here is the link. http://www.buya123batteries.com/default.asp
$129.95 each.
The battery has 8 M1A cells. With over voltage, under voltage, temperature, balancing circuitry built in. Two fuses built in. One is a replaceable 30A. Another is non-replaceable 120A.
You can probably replace the ATO blade style fuse with a 40A version.
http://www.mouser.com/Search/ProductDetail.aspx?qs=cR7Qvk1oinnxW2OeUAnGZg%3D%3D
Undesirable characteristics: There is no nominal weight defined in spec sheet. The terminals are 1/4" faston tabs for UPS application. The modules can be run 10 paralleled, 4 series maximum. 4S sounds low, but I think it's limited by the fuse rating. Non-replaceable 120A fuse.
Anyone going to buy one and hack it?
*edited some typos.
$129.95 each.
*edited some typos.
