A2B Velocitti 24 external battery replacement
External battery confirmed to be dead (http://electricbikereview.com/a2b/velociti/)
Looking for recommendations re companies (CA or USA) that repair or offer replacement alternative battery etc.
So far drawn a blank trying to contact companies suggested on EBR forum to other A2B owners looking for parts etc.
Good luck finding a decent stock replacement, i wasted months before giving up.
I may suggest a couple of options..
1) track down someone who can replace the cells and rebuild your pack.
2) forget that stock rear A2B battery, and replace it with a reputable “Shark” type pack attached under the front downtube . This will give you choices of supplier, pack capacity and voltage (big advantage) andmake the bike much nicer to ride without that big lump hanging out the back !
Tip >> if you do go with option 2, do not lose the original battery connectors...they are also impossible to source these days.
