Eviltwin68
I picked up an older steel frame (2005 or earlier) Hase Kettwiesel recumbent delta trike. If you are not familiar with Hase they are probably the best delta style trikes made, especially if you judge them by how much they cost. I'm generally a cheapskate when it comes to used bikes but I will admit to spending more on this bike than I usually do. I bought this one online from the BicycleMan in NY and had it shipped down in a box after being taken apart and carefully packed.
A couple of days of fun and it was back together and on the road. But my was it slow compared to my other two recumbents which both have mid drives.
Last year I built a third recumbent with a mid drive, a Sun EZ3 which is an ok bike with the mid drive but it mostly sat in the shed since space is tight in the garage and I was sharing a battery from one of the other two bikes. So I decided I would move the motor and battery from the Sun onto the Hase. That means there would be three bikes in the garage, but the Hase has the ability to do this:
Today was the first day of working on the Hase delta. Unlike the other bikes, this one has some quirks that I had to work around. Where to put the battery and mount and would the motor work with the drivetrain. I figured I would start with the battery.
Its a long bike with a main tube and under seat steering with a long rod on the left of the bike. It has plastic black pex tube for the chain on the right that also limits where the battery can sit. I thought about just using a triple bob mount on the main tube but the battery is just a bit too wide and would push into the chain and disrupt the chainline a bit. Not enough room under the seat either so that left somewhere on the back between the wheels.
I ended up repurposing the mount I made to sit on the back of the curved tube. I cut a bit out of the aluminum to accommodate the cluster. A couple of smaller U bolts seems to hold it in place tight enough.
I next tackled mounting the motor. Its a TSSDZ8 that worked well enough on the Sun. I pulled off the old crankset and slid in the motor. Normally I would hang the motor down, but in this case the steering rod makes that impossible, unless you want to monkey with it and I did not. So it will sit on the top of the main tube and should work just as well.
That's the progress up to date. I'll post more as I go along.
