Powervelocity.com
I've been building ebikes for a few years now, both for myself and for customers. It looks like the focus has been primarily on the drive trains (such as mid-drive vs. hub motors), but it would be interesting to hear some opinions as to what would auxiliary features might be sought after, especially those that would make your ebikes more safe and fun use.
These are some thoughts that have been lingering in my mind to get the discussion going. I understand some of the ideas are not brand new but still it would be nice to hear some perspectives on these things.
- Traction control, ABS (anti-slip can be life saver on snow and ice for example)
- Integrated intelligent lighting system (stop signal, automatic turn signals, automatic high/low beams, maybe something else)
- Collision avoidance system (say power is cutoff and strongest regen is engaged if objects are approached at high speed and there is an imminent possibility of collision)
What else?
Feel free to chime in!
Master list of Desired Features:
- Blind spot detection with haptic feedback and/or buzzer, light indicator built into the mirror
- Auto high/low beams with manual override
- GPS tracking with online registry (this is already available as standalone products, I use it on my bikes for customers that ask for it), further integration with other features available via smartphone app
- Immobilizer (already available in alarm systems - remote start, arm, disarm, wheel lock, gps tracking), further integration with other features available via smartphone app
- Collision detection: either passive with a buzzer/haptic or active (cut off throttle/engage strongest regen)
- Traction control with manual override (probably will make sense only on ice and snow)
- Other smartphone features:
a) Check state of charge, notify when empty or charging completed
b) Proximity ignition on/off secure key (enabled via Bluetooth, RFID or such)
b) Toggles for customizing accessories
c) Tire pressure monitoring with notifications via smartphone app
- shocker on grips (although easy to implement, it might be illegal for use)
What else?
