Advice please on Ardunio
urga
Hi
I am trying to get the button controller to work with my vesc(Focbox) via an Arduino nano. I've programmed it via Visuino,thanks to the code sent from Kepler. The code seems fine as it shows the required output via the serial monitor.However,when I connect it to the Vesc I have no readings showing on when trying to map the ppm ? I tried changing the Baud rate on the Vesc as the serial monitor was showing 9600, just in case that was affecting it.
I would greatly appreciate any advice on how to troubleshoot this problem. Please bear in mind I am a complete beginner in electronics :oops:
Cheers
David
