They are the same motor, tp power makes them.
As I've said, your motor will give it's rated power at rated rpm. Different KV only means that it has different number of turns, and according to that thicker or thinner wires in motor, and thus it can either be optimized for lower current and higher voltage, or vice versa. So, if your motor is 150 kv, and rated 10 kw at 25000 rpm, you must provide 166 V and 60 A if you want to use full power from your motor. If you have the same motor, but lets say 700 kv model, you must provide it with 36 V and 277 A for full power.
But, if you use 150 kv model, and use it with lower voltage, let's say 72 V, your max rpm will be 10800, and that's only half of it's rated rpm, so you can get only half of the rated power.
Power equals torque times rpm, and torque is defined by motors physical construction, so you can't increase it behind rated values. You could, by increasing current, but you would end up burning your motor. Note that if you have lower kv, that means that motor can accept higher voltage, but lower current, so you can't just use lower kv motor, run lower voltage, and higher current.
