sorg
- Joined
- Apr 29, 2018
- Messages
- 20
Hello !
I have an ebike (BBS02 based) with a 48V 13s4p battery.
I have recently changed the stock BMS with a Daly "smart" BMS with Bluetooth module.
I am quite happy with the BMS itself.
More specifically, the balancing is efficient which was not the case with the original BMS. I have been using the daly BMS for a few weeks now, and I have slowy reduce the "unbalance" from 200mV down to 20mV.
The main downside is the size of the BMS (quite bulky) which makes it probably not usable in most shark or dolphin pack. (I have a simple shrink wrap package, so this is not an issue for me).
I am quite disapointed however by the Android App,
I have owned a xiaoxiang bms in the past, and the app, despite an ugly UI , had a lot of features.
The daly BMS app on the opposite, is quite fancy to the eye, but is very limited regarding the features.
I a missing more specificaly:
- Curves display to have a better understanding of each values over time (Amps, Volts, Watts, etc...)
- Total of Ah (or Wh) used since last full charge in order to monitor precisely the "real" pack capacity.
Do you know alternative apps that would provide these features ?
