Hubs/Wheels on regular bikes ( Quick Release , 9mm skewers ) have fallen off bikes enough times for a number of lawsuits , I could go back and ask the person I know who has been in the Bicycle Industry for over 20 years how many times,
But I do not really need to. He told me over a year ago that it has been a big enough issue / cost to bike Company's .
Also ... I never said that the lawsuits were from weak frames , I will not insert a roll of eyes here, Perhaps you just mis-read or did not understand , what I am talking about .
he / and now I , am taking about all the lawsuits from wheels dropping out of the fork/dropouts , and that is one of the reasons that bike MFG's are moving over to Through Axle's albit just one of a few reasons.
If you do not want to accept that , well what else can I say ?
But even if you like 9mm quick release axles , you are missing a very important Point , And that is that many of the bikes being sold these days have Through Axle Front and Rear Wheels/Forks and Rear Drop Outs .
So ... Since we here on E.S. convert bikes to e-bikes we , Need , to have available rear hub motors , Period !
Also in regards to wrenches and flats .
1) My last flat was from a drywall screw that was 2 inches in length , and went through not only the tire, but both sides of the tube and even scratched the rim tape. There was no way I was going to fix that by just taking off the one side of the tire and patching it up, there was such a big hole in both sides of the tube and tire, that I had to have someone with a truck take me back home. ( I did try to repair it without taking off the wheel, but when I got one side of the tire off, and saw how big the 2 holes were in the tube I knew that it was not possible , like I had done before when just a small industrial staple put a patchable hole in the tube , so I know all about patching a tube without taking off the wheel, unfortunately it is not always possible to do a simple patch repair)
2) After the last flat I decided to carry a wrench , at first a large spanner, and now I am using a Park Tool 22 mm Cone Wrench Tool. However it is still too big for my liking , I have to strap it onto the frame, yes it is possible, but not desirable.
3) You are missing the point about 12mm rear through axles, Bike MGF's don't make thier bikes for us to make into e-bikes, when I speak of the rear triangle of a bike being stronger with a through axle , it is in comparison to 9mm drop-outs .
I am speaking of the bike ... Frame , being stronger back there.
Since most bikes now have frames that use Through Axles, I want a Through Axle Hub , even though you might think the little amount of difference in fixing a flat is small, The Fact is ... All the Bikes Frames that I want to use in the near future, including a F.S. Frame I have not build up yet , is a Through Axle Design .
Hillhater said:
I can see the benifits of for a front through axle hub/motor
But How does a thro axle at the rear make changing a tube or fixing a flat , any easier ?
....and i dont recall ever hearing of a rear hub falling out of the bike !
[/quote]
I suspect you are just postulating here !..
Wrench size ??..really !..if you are actuallyconcerned about it...find yourself a custom liteweight wrench.
Most punctures can be repaired without removing the wheel, but if you are prepared to change a tube or tyre, carrying the necessary tools is a minor issue.
If your powered hub becomes loose, you are going to have a few issues with chewed wires etc, way before its loose enough for the hub to drop out.
I have had 2 rear QR axles snap completely (2pieces) without the wheel dropping out ( chain hops, brakes drag, etc)
I have never had any of my hub motors work loose.
And...i still do not accept that a 12mm through axle will be any more rigid than a 14mm axle correctly installed.... (with a big wrench !)
..and law suits from weak rear triangles ??
[/quote]
